Help on U-joints | Ford Explorer Forums
Help on U-joints
briwayjones
Manual Master
Location
Maryland, USA
Eldersburg, MD
2000 Ford Explorer XLS
Some questions on u-joints.
http://store.summitracing.com/egnse...94803602+4294925134+4294744933+115+4294907048
On this page it says one of these u-joints is solid and the other two are not. What is the difference between solid and non-solid u-joints? Do I want the solid, are they stronger I take it? Are these a decent brand? What brand would you go with? These fit for both the front and rear u-joint? And finally, these are for a Sport Trac, would they be the same for a 2003 Sport?
As I understand it, solid u-joints are non greasable while the non solid ones have a grease zerk in them to regrease the joints like you would a tire rod or ball joint.
~Mark
For longevity, I'd go with the non-solid as long as you're not running like 33"+ tires or whatever.
Because they're greaseable? They're for my Sport with a SOHC so there's a little more power than a OHV. Plus I will be adding some power to it, nothing like a turbo or anything, but a underdrive pulley, tunes, ect., will it still be strong enough? What do they come with from the factory? I take it solid because to my knowledge there is no grease fittings on them?
Yup. What kills U-joint 90% of the time is not stress or torque but rather a dried up cap -- which leads to the infamous bird chirp sound as the needle bearings in the cap are grinded away with each revolution from the lack of grease.
Yes a hollow one will be strong enough. Remember that the driveshaft experieces at the most 227% less torque than the axle shafts if you have 3.27 gear ratio. If you have say the 3.73, then the driveshaft will be subjected to even less - 273% less torque.
Yeah I think they come with solid. But with regular greasing every whatever thousand miles, a hollow one should last forever.
