bigeasy19781
- December 16, 2010
- spartanburg, sc
- 95 xlt
alright ya'll first post. i got a 94 explorer with a 3 in lift on it, i flipped it at the end of last summer so all winter long i have been working on putting a new body on it. Now im done but have a few problems. During the process i replaced the front pump seal on my transmission. Now with the truck back together, the transmission wont pull. All my linkage is hook correctly and you can watch it move the trans from park to 1st gear no problem. also my transfer case is in 2wd. i can feel the motor bog down like it went into gear but no pull. Also the transmission did work great before the tear down. if anyone has any suggestions i would be greatly appreciative.
a couple things i was suggested, my lines to my trans cooler were hooked up backwards. ( havent tried switching them yet)
also that there wasn't enough fluid. (i ran the truck until i got warm then checked and its still full)
