gsims25
- April 20, 2011
- Philadelphia
- Explorer 98 XLT 4X4
So here I go, bought a used 1998 Ford Explorer XLT 4X4 about four days ago. Started over heating, and no heat was coming from vents so I put a thermostat in, (since the guy before me never had one in.. wierd). After that water pump started leaking really bad, so I replaced that a day later. Put everything back together, no leaks after about 15 min antifreeze start coming out of radiator cap. So I get a new cap and put it on, car it running great get about 10 miles down the road and I hear a load pop and the engine is smoking and starts to over heat again. Pull over and antifreeze is pouring out the bottom of radiator. I thought it was the hoses, but I poured water in radiator and it was pouring out the bottom of radiator. Help, has this every happened to anyone before and when I replace the radiator will it fix the problem, never had this happen before.
