help Robert dirksen with a4ld trans | Ford Explorer Forums
robertdirksen
redding ca
1992 ranger xlt
I have a 1992 ford ranger xlt 4.0 v-6 2wd automatic trans problem I need help with I've been told its torque converter its a weird noise I does get louder when rpms r reved up anyone help please get back to me asap
If anyone in redding that has a lift or can give me a better help what it is please text me at 5309173904
Robert, I moved your thread into our transmission forum. Hopefully one of our tranny gurus will see this and be able to help.
Sounds like a flex plate spacer. I had the same noise from my explorer. They are made of plastic. The PATC transmission center sells a metal one it's probably the 6 bolt one, cost is $15 and they are quick with delivery. It's also available on Ebay, PATC has a store through there. Just type in a4ld crankshaft spacer. It goes in between the flywheel and crank shaft. Stock ones are known to break. Could be the torque converter but that wouldn't be my first choice.
