ddenton749
- March 27, 2002
- Kennett Square, PA
- '93 XLT
1993 Explorer, V6, 177,000 miles, automatic.
The problem: This started about two days ago. The idle is generally rough. If it sits idling (like in traffic) it will stall if I don't tap the gas. If it does stall, it starts right back up again. It runs VERY rough when the engine is cold. It behaves like it has a vacuum leak but I can't find one. The vacuum gage reads 14-15 inHg. Compression is good. Plugs are good. I replaced the upper and lower intake gaskets last October (water leak) and it has run fine since. I re-torqued the intake bolts but they seemed tight. I replaced the water pump on Sunday but I doubt that has anything to do with it. I also cleaned the Air By-Pass Valve with carb cleaner.
Could it be a bad Air By-Pass? Bad or dirty MAF?
Probably Unrelated: I'm not getting current to the fuel pump relay to activate the fuel pump. The car runs fine if I jumper the fuel pump relay terminals. Is it a bad EEC? Could this be related? The inertia switch is good.
Anyone can respond to ddenton@kellyengineers.com as well as to this thread.
Thanks,
Don
Thanks,
Don
