darkostoj
- April 14, 2005
- Rochester, MI
i drove my buddies 4wd 04 explorer to work today to fix his car for him. It had all sorts of vibrations.
I changed the rear driveshaft u-joint some vibes went away driving high speed and the clunk dissapeared from going in reverse to drive (it was bad)
i put on new front rotors and pads - vibe went away when braking.
the last vibe was a vibe at 50mph + and got worse the faster you went. It felt like it was coming from the front end. At highway speeds it would go away when turning left and get worse when turning right. He already had a shop do his passenger wheel bearing...so no brainer thats its a drivers wheel bearing right? I put a new one on, and not only are the vibes still there but the ABS light came on in the dash.
I'm gonna go put it on the lift again and inspect everything, but I have NO IDEA what it could be. I'm stumped
