Help urgent | Ford Explorer Forums
Help urgent
Explorer2011
Pensacola, Florida
98 Explorer V8
Installed a medal door handle now I'm tryin to think how u reset it to where the handle actually works as it does nothing when u go to open it
Also have new acuator tryin to change and gettin the new hook on seems impossible to get the silver holder over the plastic what's a easier method?
If you are talking about the lock actuator, remove it, then put the hook end through the linkage. Just pry the actuator from the mounting bracket. Bend the bracket out so the actuator comes loose, then bend the bracket back so it will hold the actuator.
Yeah well it was a new Actuator so i had to put a new hook on and it was hard as hell to put on.. took a few hours you had to jam it on with force use grease etc lol just never remeber it being that hard before... but finally got it workin phew
