D Hook
- October 10, 2010
- Omaha, NE
- 06 Explorer Limited V-8
No rear reservoir; it all feeds from the reservoir from under the hood. Should be able to see the hose running to the back window from that front reservoir. Mine had come apart at a junction under the hood, low on the passenger side and was pumping fluid on the driveway so it was easy to spot. I've read of others having to pull the headliner down a little back by the hatch to see if the hose is connected to the spray head. When you activate the back sprayer, are you seeing any puddles anywhere on the ground or inside the vehicle?
