My 2002 2WD Explorer has 175,000 un-interrupted miles on it (bought new in 3/02) and the rear washer fluid does not work. When I try to send some fluid from the resevoir to the rear, I can hear the pump, but no fluid. Any ideas or forum links that will help me? Thanks in advance........
Is this part okay? I took out the screws to look there, but it's still dark out... Is that nozzle okay on your vehicle? It should be clear in those little areas... I would suspect the nozzle is the problem...
Find the line under the hood where it leaves the pump. Disconnect it and disconnect the line where it goes into the nozzle in the tailgate. Run the pump to see if you get fluid out of the pump. If so, then blow compressed air backwards through it from the tailgate end of the line. If you have any blockage, that may push it out. If air flows freely and you have pump action (DON'T go there ) then check the nozzle for obstructions.
There's only one tank on the newer trucks, and it's up front. The rear washer on mine had stopped working and I found the tube had seperated at a joint located right on top of the passenger side front wheel well. It was pretty easy to see and shove back together. Works fine now. Good luck.
Just got a 2003 Explorer for a work vehicle, and the rear washer does not work. It pumps just fine, however it puddles underneath the vehicle at the right side of the rear bumper. I can see it pouring out of the body of the vehicle and smell the fluid inside. Do I have to pull the interior panel off in the back of the car to get to the line?
Mr. Wolfzr2, the line has probably popped off just under the rear most passenger window. I wrote a description on here a while back how to fix it permanently. Basically, it took me less than 10 minutes (after I already paid the dealer $65 the first time - argh!). Pull off the top rear trim, pull out the right rear trim just enough to see the line (have some one run the pump a bit if you have trouble seeing it). You can put a little gorilla glue on the NIPPLE, not the tube and push it back on. Then wait a day and try (actually try it before you glue it to make sure it's not obstructed.) Subsequently if you try to use it when the fluid is frozen, it will pop off up front in the engine compartment - an easier fix.
I found the line disconnected from the fitting in the engine compartment, on top of the passenger side wheel well. I put it back on, and everything works fine now.
