Help with door sticker codes please | Ford Explorer Forums
shaunv8
perth australia
97 xl
hi all can someone please break down the following and tell me what i have and havent got. its off a 97 xl on OZ. thanks alot
EXT PNT: FL |RC:9H | DSO:
WB | BRK | INT TR | TP/PS | R | AXLE | TR | SPR
112 4 G2 8 D4 D BF
THANKS AGAIN
Soeey guys but the codes are all supposed to be spaced above one another below n above the line but the post compresses them together. Hope you can all help shaun
you have a ford 3.73 gear ratio with a limited slip
buy yourself a chilton's or haynes manual... it has all the decipherings in it... or just search the site.....
Weird, I tried to fix it, but it compresses them together again...
Anyways, the "D4" means the rear axle ratio is 3.73, with alimited slip, as Jim said.
The WB is wheel base.....112
