S
scotts97eb
Hi,
I've got a '97 4.0 SOHC, EB, (Control Trac AWD? The button selections are "Auto", "4wd High", "4wd Low"). VERY strange things are happening with my 4wd system. If anyone has had anything like this happen to them, I would really appreciate hearing about it - I'm dreading going into a repair shop with such an ambiguous sounding problem... I should preclude that I just had my transfer case fluid changed about 3 weeks ago, and I've never had any symptoms like this before, and nothing up until a couple days ago. Here are the symptoms:
1) Two days ago, I noticed that after taking my foot off of the gas and coasting up to a stoplight, both the "4wd" and "Low" lights in the dash blinked on and off a couple of times. This has happened more and more over the past two days. When this happens, there are no other symptoms. Yesterday it was sometimes happening while coasting (releasing the accelerator pedal) on the highway.
2) About 4 times now, after starting the engine and starting to drive away, the transfer case acts like it is locked in 4wd - you know that resistive feeling when doing a tight turn on dry pavement - and then suddenly there's a "clunk" (noise and feel), and it goes back to normal. It's like it's starting out locked in 4wd (and the switch is on Auto, and the 4wd dash lights aren't on), and then after a few seconds it disengages.
3) Just this morning, after arriving at work (and having both of the above problems happen along the way), I pulled into a parking spot, put the transmission in Park, and turned the knob to "4wd Low) - no dash light came on. Then tried "4wd High" - still no dash light (or typical noise that the auto locks make when engaging). Turned the engine off, then back on again, repeated the procedure, and it worked fine... Very strange...
I'm going to check my transfer fluid level when I get home tonight, but if anyone has had this sort of behavior, your help would be MOST appreciated. Thanks,
-Scott
-Scott
