help | Ford Explorer Forums
help
soapman
cambridge,ohio
2001 ranger edge
2001 ranger edge lurching and jerking when running a constant speed. seems fine when accelerating. no check engine lite. 3.0 engine 36000miles. any advice? I WILL NOT DRIVE A CHEVY!!!! :cool:
could not tell you....but i would go on therangerstation.com and post there....some one there would know for sure
could be either of the two things... fuel or electrical.
Check the plug wires making sure they are not arcing, check the plugs for proper gap and always use MOTORCRAFT PLUGS.
Fuel filter replace and check for proper fuel pressure on the injector rail. I am not sur of the lb require, but you might want to check to make sure..
I am not familiar with the 3.0 at all, but the guys at ranger resource probably are.
click here
I avoid TRS at all costs.
