93 x
- October 29, 2009
- bothell washington
- 93 xlt
So i finally decided to post it i did not build the whole thing but i have had to redo a bunch of front axle geometry and go through all the lift stuff because of the hack owner before.
ford 8.8 locked in rear with disk brakes with the PROPER master cyl 4.88's and new seals and bearings and everything.
66 bronco dana 30 front with yukon shafts 4.88's new seals and bearings and everything. warn manual hubs.
brand new bilstien shocks all around custom shock mounts for rear and fronts.
5 speed with stage two clutch.
5.5 inch lift james duff front coils with james duff coil buckets. 6 inch drop pitman arm Extended radius arms . custom made trans/radius arm mount.
custom made drivelines with new ujoints front and back.
35x12.5x15 wildcats
2 inch body lift
smittybuilt tube front bumper
working 100 watt off road lights wired with relay
rhinolined inside, rocker steps and little bit of fender
manual transfer case
front projector headlights with hids.
full custom exhaust.
Shot at 2012-04-15
Shot at 2012-04-15
Shot at 2012-04-15
Shot at 2012-04-15
Shot at 2012-04-15
Shot at 2012-04-15
Uploaded with ImageShack.us
35x12.5x15 wildcats
2 inch body lift
Shot at 2012-04-15
Shot at 2012-04-15
Shot at 2012-04-15
Shot at 2012-04-15
Shot at 2012-04-15
Shot at 2012-04-15
