On the rear differential there should be a stamped tag. Get the numbers/letters off that.
Someone else should clarify, but I think there is an LS in the code if it is limited slip
If you have limited slip, I believe that if you jack up the rear axle and spin one tire, the other should spin the same direction. If you don't, the opposite tire will spin in the opposite direction. I'm shure that someone else can help expand on the specifics. Hope this helps you!
