hey guys and gals | Ford Explorer Forums
hey guys and gals
duggyd123
delphi in
95 xlt, 97 eddie bauer,79
how do i tell( i know i do)if i have limited slip. i am asking for my friends ex, will it tell you in the vin or anything
On the rear differential there should be a stamped tag. Get the numbers/letters off that.
Someone else should clarify, but I think there is an LS in the code if it is limited slip
If you have limited slip, I believe that if you jack up the rear axle and spin one tire, the other should spin the same direction. If you don't, the opposite tire will spin in the opposite direction. I'm shure that someone else can help expand on the specifics. Hope this helps you!:D
yes there should be an ls in the axle code. it'll be on the diff or inside the drivers door. generally both places
It will have a "D" as the first digit in the axle code on the driver side door tag.
