whiteboy91ranger
- May 4, 2010
- santa clarita, ca
- 1991 ranger
ok i have a 91 ranger the 3.0 i know crappy motor anyways once warmed up it drives fine until i step on the gas once it gets about 4000rpms it cuts out and dies and wont start for and hour or so took it to a buddy's shop and obd1 said o2 sensor running lean this is what i have replaced
fuel pump
fuel filter
distributor cap
distribut0r rotor
spark plugs
sprark plug wires
air filter
cleaned the iac valve
checked and traced wiring for shorts or damage
fuel pressure was low yesterday changed the pump and worked great thoughti found the problem was very happy then later today started acting up and wanting to die after i step on the gas now idles real rough and low
when i disconnect the maf sensor idle turns up
no vacumm leaks
please help any input would help :rangertan::rangertan::rangerred::rangergreen:
fuel pump
fuel filter
distributor cap
distribut0r rotor
spark plugs
sprark plug wires
air filter
no vacumm leaks
