Hi Explorer Forum | Ford Explorer Forums
Hi Explorer Forum
Devin_Rogers
Memphis,Tn
2002 Ford Explorer XLS
Hi I have an explorer that's an 02 and I can tell you I have basically rebuilt the truck with new axle,4 rims & tires,dayco belt,rack & pinion,high pressure hose,power steering pump,2 calipers,4 shocks, 2 upper arm controls,2 abs harnesses,duralast gold battery,new alternator,4 rotors,duralast gold maxx brake pads,3 ac compressors the keep friggn blowing,tune up,transmission solenoid pack,trans filter,trans fluid...mercon 5..,oil change,radiator & fan,4 tie rods, OMGGG WTF!!! And now my brake pedal goes STRAIGHT to the floor no pressure AT ALL at first whenever I stopped at the light my brake pedal would instantly loose pressure causing the truck to roll....I know ...scary shhhhh...so im like a quarter mile from home and try to make it to the house but to my suprise my brake pedal only went to the floor so after a few squirrels & curbs later I made it home ..hopped out like looking inside the reservoir I could see 54.3 air bubbles inside it so i bled all brakes including the master cylinder....nothingIm soooo mad at fords bullshhhhtt after all of FORDS work I had to come over. I could have gotten a car note.............FROM BENTLEY......F FORDI KNOW ITS NOT A MIDDLE FINGER BUT ITS AS CLOSE AS I CAN GET
Welcome to the forum. What mileage is on the truck?
