HID headlights on 2003 Explorer, need anything? | Ford Explorer Forums
4FordFamily
Been there done that
Fishers, IN
'16 Sport, 08, other ford
I own a 2006 dodge charger, and I needed a special harness for HID lights (not just your typical power/ground/relay/fuse kit. It had to have capacitors and stuff wired in to it to level out the load of the HID's, because stock bulbs run at 55 watts, and standard HID's run at 30 watts. HAL (the system that monitors this stuff in a mopar) would then try to turn off/on the headlights, looking for the proper 55 watt power to them.
Do we need anything like this for 2003 Explorers XLTs'?
I bought a kit from here really cheap. I got them in a couple cars and friends have their kits too. http://vvme.com/ All I did for this kit is unplug headlight and plug in the kit. It is plug and play. No install what so ever. Great lighting too. Tho I cant figure out how to aim the headlights.
yup, I've been using vvme for about 2 years now, I used to buy their kits for 70 bucks (2 years ago) and sell them for 150. Now, they cost about 58 or so shipped, and everyone knows about them. So that's all I need is the kit? No special harness for the daytime running lights?
i always say you should use a wire harness to power the hid ballasts...i retrofitted projectors in my headlights...and ran a wiring harness...basic power/ground/ relay harness...at power up the ballast does draw a lot of power and needs that from the battery...the stock harness shouldnt be used for that...even though many people have them connected as plug and play there is a risk of a short happening...up to you
Does anyone have pics of this kit in their X now? So this kit basically runs off of the stock headlight assembly without the fish eye type of projector housing?
do you have a pic of your harness setup and ballast locations?
yes, pics please! Ty for your contributions!
I just ordered a HID kit from VVME (9006 4300K) for my 2003 Limited, I'll document how it goes in when I get it.
I just ordered mine too, we'll start a thread and post pics! :D
ok keep us posted. What kind did you get? Bi-Xenon?
i dont have too much knowledge of electrical, which is why the plug and play kit from vvme is ideal for me. But i want to do it right, and if its better to use a harness, then i want to do so. only thing is i dont really know what you guys mean when you mention the harness :( , so what does it do, how is it connected and would I be able to do it, or for the sake of not electrocuting myself should it be done by someone else? thanks for any responses
search HID wiring harness on ebay.
It's a direct connection to the battery, a ground, a fuse, and a relay. It plugs in to your stock bulb harness, and everything else is the same. Very easy to install, much safer. Mine is ordered. MY VVMEHIDs:
Hey guys, this post has sparked my interest in getting some HID in my 2002 XLT. I assume it's all about the same....so my question is this.
Will I see much of a difference than my current Silverstars?
What color temp did you guys go with?
Thanks.
copied from the FAQ section on that site 5200K lamps are approx 10% brighter (measured in Lumens, not degrees K) than the 7000K. If you want lighting performance the 5200K HID lamps are the best. In our opinion 7000K has the best and most attractive light output. you should notice a pretty big difference over stock type bulbs
Thanks.
Thanks, I'm looking for the brightest, whitest light. I live in the midwest, deer country, so I'd like to be able to see them. I'd like it to look good, but I guess the bright factor is most important.
From the vvme web site:
4300K has an approximately 3100lm output, which is more than 3x the light output of the traditional halogen light and is the color temperature with the most output. The light appears fairly white, and has light yellowish hue when reflected off the road identical to the OEM HID equipped vehicles. It is ideal for customers who do a lot of back road or canyon driving and need the optimal visibility.
I was surprised with the VVME site - the HID kit was shipped from Hong Kong, and arrived at my house in Ohio four days after I ordered it. That's quick! I ordered this kit with the 9006 bulb, 4300K (brightest) temperature. I don't like the hyper-blue look, and am more interested in bright lights, so I didn't order the higher temperature bulbs.
The kit comes with two sets. Each set contains a ballast, a bulb, and a wire harness. The wire harness has a waterproof connector that plugs into the connector that the original OEM halogen bulb goes into. That wire runs to the ballast, and is where the ballast gets its power. Another wire, hard-wired to the ballast, ends in two waterproof connectors. These waterproof connectors plug into an identical set of connectors on the bulb itself. You can easily remove the HID kit and replace the original halogen bulb if you wish - none of the truck's wiring harness is cut or modified.
Last night I finally got some time to install it. The install took about an hour and a half. Here's what I did:
First: to remove the light bulb - this is not covered in your owner's manual: On the top of each headlight assembly, you will see two small semi-circular tabs. Pull these tabs upwards - you may have to use a wrench or screwdriver to put some force into it, as they tend to get stuck with road salt and grime. Once they move upwards, about 3/4 inch or so, the headlight assembly will release. You can then pull the headlight assembly forward and out of the truck. It will be attached only by the wires. Rotate the main beam light bulb counter clockwise, and the bulb will come out. Reinstallation is the reverse of removal, and ensures you do not change the headlight's aim when replacing the bulb.
I started on the driver's side. Once I had the bulb out, I removed the battery from the truck. I drilled holes in the inside fender and mounted the ballast bracket. I then slid the ballast in place. I plugged all the wires together, then put the battery back into my truck:
I turned the lights on to test it - and nothing. The passenger side (which still had the original halogen bulb in it) came on, but the driver's side was dead. Swearing ensued.
I got my multimeter out, unplugged the main power connector at the ballast, and checked the voltage. To my surprise, it was backwards - it showed -12V instead of +12V - the positive was on the black wire, and ground was on the red. This meant the plug at the lamp connector was wired backwards.
I clipped these wires, reversed them, soldered them back on and put heat shrink tubing around them. I plugged it back into the ballast, turned it on, and success!
Before installing the second unit, I cut and reversed its power supply cable as well. For the passenger side, I located the ballast in almost the same place as I did the drivers side. In this case, I had to move it upwards slightly, so that the air cleaner cover would clear it when it was removed:
This one went much faster than the first one. 15 minutes later I was done, and both headlights were working.
So what do I think? Well the ballasts do make a hell of a buzzing noise when they first start up, and continue to do so after they have gone to full brightness. However you can only hear it from outside the truck - inside you can't hear them at all.
The lights themselves are startlingly bright - much whiter in color than the original halogens. This can be seen by turning on the high beams, which are still halogen. The high beams look positively yellow in comparison.
The cutoff at the bottom of the light is much more pronounced, and the spread seems wider, which I was not expecting. Overall it is far, far brighter than it was with the halogen bulbs. I drove around the block with them, and the snowbanks positively glowed. I'm very impressed, and highly recommend this kit!
Nice post gmca, thanks for the assistance. Is there any way you could post a pic of the highs vs the new lows? In your opinion is it worth the money?
