HID Lights | Ford Explorer Forums
HID Lights
interscope8
Purdue University
2001 Sport Trac 4x4
Hey all, just decided to put this at the top of my to-do list. I almost hit a dear the other night and as it turns out my bulbs are the original ones from the factory... time for new ones anyway lol. Might as well get HID ones.
I found some black faced headlights with an HID kit and 4300 bulbs. Have black taillights on the way and need some help getting LED or similar bulbs there.
Im a novice to all this lighting and what not. Anything I need to look for when I buy this stuff?
For example, the headlights im getting come with 4300k 9007 Bulbs. These will work with my truck right?
Yes, 9007 is your headlight bulb. Going the route of HID, just throwing them in a reflector housing is gonna throw off weird patterns in the road, plus alot of glare, causing every oncoming driver to think your driving with your brights on. You CAN aim them to help that, but theres still gonna be glare. You'll also loose your high beams.
Its a little more costly, but I would opt for a retrofit. (Projectors, put into the headlight housings basically) Projectors dont throw any glare, and the beam on the road is perfect. Its gonna cost a bit more, roughly 300~ for the projector and HID kit. Then youll have to buy clear or black aftermarket housings.
any useful links i could use to buy these things?? :)
Sorry for the slow reply, im actually outside putting my new fogs & HID kit in :D
Anywho, this is the kit that most go for. From what ive read, and looked up, its the best bang for the buck, plus your getting a great HID kit. (The eBay link to those lights, that kit probably wont last, it will flicker, sometimes not turn on, etc.)
http://www.theretrofitsource.com/product_info.php?products_id=141
And then you'd just have to get something like:
http://cgi.ebay.com/ebaymotors/01-0...Model:Explorer+Sport+Trac&hash=item4aad60c8f6
Those lights are the same as the lights in the eBay link I posted, the ones from eBay, but just so i understand, the HID kit issues lie with the bulb, not the housing right? So that 1st link you gave me would be the actual lighting element and that housing would work without the glare
the first link is the retrofit kit. It comes with the HID kit, projectors, shroud, etc.
You have to mount the projectors in a housing though, which is the 2nd link I posted. Theyre the same headlights that you linked, BUT without the el-cheapo HID kit.
HIDs WILL work in a stock housing, and be alot brighter than halogens (As long as theyre 6000k or below), BUT they will blind oncoming traffic, and have terrible patterns on the road. (It will be blotchy)
