hid not firing question | Ford Explorer Forums
uchi
niagara falls ontario
2001 sport
so i installed my hid kit today. everything is mounted the way it should be and at first everything fired perfectly. i went over to my gfs place, shut the truck off, went inside for about an hour and a half, went out and only one light fired. i turned them on and off a few times nad still only one fired up. got to the end of her parking lot and the other turned on. stayed on the entre ride home. got home, turned the lights on and off a few times and both fired every time. went out to walmaart for an hour, got home and again only one fired up. im hoping its a ground issue of some sort. the driver side which works all the time runs to ground on the rad support by the battery where all the other wires run to. the other ground i just drilled a hole into the rad support and put a screw into it. so thats what i think it might be. any input on this before i start playing with things?
