high flow air filter | Ford Explorer Forums
sweetexplorers
Muskego, Wisconsin
93 explorer Eddie Bauer
Where should i relocate the temperature sensor after the airbox is out???
I have a 93 explorer
Temperature sensor? If you're talking about that thing in the top of the air box cover that has 2 vacuum lines going to it? Take it out, plug the lines, and forget it. It's not needed.
I wasnt sure what it was for so i took the little metal deal off the box and just plugged it back into those vac lines.. figure better safe than sorry.
you could go buy a vacuum T and plug both lines into the crankcase vent hose, that way you are still drawing air. Thats what I did when I installed the intake on mine.
most peopel jsut shove a bolt in them and ziptie them to something so they dont dangle.....
