atblue5spzx3
- August 20, 2010
- Tacoma WA
- 1995 XL 5sp 4x4
I have a 95 Explorer with a 4.0 of course, about 165k on it. VERY good shape, got it over the summer.
About 1000 miles ago, I went to synthetic, did the change and filter myself. No problems. Then, this week, I've noticed the oil pressure gauge is reading slightly higher than normal, usually the needle is in the back of the oil can emblem, left of center. Then the past couple of days, it's at times gone up to 80% of the range, and particularly at low RPMs, like when I'm cruising at 45 in 4th (5 sp manual). As an experiment, I went from a low RPM and gave it a bunch of gas and brought the RPMs to just over 3k and the needle almost literally fell as the revs rose until it was midrange again. I'm thinking gauge or sending unit, but I've never seen this kind of problem with a vehicle I've owned.
I have been checking the oil and in 1000 miles, the quality and capacity hasn't changed at all, perfectly full. It doesn't leak, smell, or have an exhaust change.
The check engine light is "EGR flow insufficient".
