High steer on radius arm set up | Ford Explorer Forums
94 Crawler
Stantonsburg,NC
'94 Ranger SuperCab
Has anyone installed high steer on a radius arm suspension D44? I was thinking of going with the Sky arms but the inner holes may move my draglink to close to the spring perches. The reason I want to do this is to get the slop out of the inverted T set up I am currently running. It is not bad but there is some play. I picked up chevy outer junk this week end at the local pick and pull, knuckles, spindles, caliper mounts, calipers for core and outer axles. Should I just get the right knuckle machined and get a right side arm and use the factory steer arms for the drag link?
Thanks 94 Crawler
