omar77
- March 25, 2007
- 02 XLT
Hi All,
I'v 02 Explorer XLT V6 4.0L, and I had just conclude a long distance travel (4500 miles trip), during I'd faced many troubles regarding a high temp alarm, when I stopped to check I found the coolant is boiling, then I wait for the engine to cool down, then increase the coolant to the indicated range, then it goes ok, it seems the coolant level sometimes goes low and makes this problem, but sometimes even in a high temp weather and when driving for a long distance also when I check the coolant level it seems ok and there is no high temp alarm. Also I noticed that after starting up the car from a cold state (like morning) and during the first few miles temp goes high for a while then calm to normal (middle), although Ford dealer had checked my truck before saying there is no leak using pressure test, but during my experience I had to add the coolant every 5-7 days, also I had changed the thermostat but nothing had changed yet, something else I noticed is that when I stop on traffic signals and during waiting when I shift the gear from Drive to Nutral the rpm is going more than usual (i.e. more than 1,000 rpm), usually it is below 1,000 rpm.
Any one could advice me, cause my ford dealer making no good help here?
Thanks in advance.
OK
Thanks in advance.
OK
