Hacra
- May 30, 2014
- Nurmijärvi
- 1997 5.0 Eddie Bauer
Hey all, in need of some advice again.
I have replaced my rear brakes; discs, pads and shoes last summer, rear brakes work good, only thing that really doesn't is the holding brake.
I have unstuck the mechanism that spreads the shoes (parking brake lever?) and greased them, but it would seem only one side of the shoes moves when holding brake is engaged and with quite liberal star wheel adjustment the holding brake barely just holds the car.
Also can the spreader be removed without removing brake shoes (i hate installing those springs).
When the holding brake pedal is pressed, it goes all the way to the floor.
Am i better off buying new backing plates with working spreader mechanism and everything else or am i getting way ahead of my self with this and am missing something important.
And if i have to buy new backing plates are these the right ones:
Ford Explorer 8.8 Right Backing Plate
Ford Explorer 8.8 Left Backing Plate
Also there's just the lever mechanism
Edit:
When i took it all apart i noticed upwards/downwards movement with the lever mechanism, afaik. this shouldn't be there and someone remedied it by welding L shaped bracket under the lever. Not sure i want to go that far yet.
I will take it all apart again this upcoming weekend in attempt to make it work again.
Edit:
