Hopefully I did it right? | Ford Explorer Forums
#1Aggie
Houston, TX
1993 Explorer XLT
Today, I changed out my thermostat with a Motorcraft 197F thermostat. My old one was also a motorcraft.
One big question I have is what is the little ball check for and and what orientation should it be in. Looking into the housing, there was a gap between 11 and 1.
So, I guessed that is where it was supposed to go. And no I did not look before I yanked it.
Since I changed it out, my temp is now up from between the O & R to between the R & M.
What is normal? I changed it out because it would take forever to warm up.
One other thing I have noticed is now the temp guage does not drop until I start the engine back up and get circulation back.
Did I put it in correctly at the 12 o'clock position?
Check ball should be on top. It's there to allow for air trapped to get out.
OEM temp for the t-stat is 195 or so.
your temperature blend door for the HVAC system may be broken and not allowing it to go full hot.
