Hot-Wire Power Windows? | Ford Explorer Forums
Johnny Glenn
Charleston, SC
02-04 Explorers
Thanks for looking in - I've got a wrecked Explorer w/ no ignition key and the windows are down. I'm trying to remove the power window motors/regulators but I need to get the windows up - is there a way to provide direct power (say from a jumper wire and battery?) to the window switch to power them up? Where would I apply the power at - which wire on what switch? Thanks for any help Also, if not is there a way to manually push/pull the windows back up?
Thanks for the link -- I thought I was on the right track w/ the thought of a wire and battery! Thanks again for your help
You're welcome! Good luck with the fix.
