How can I easily confirm if there is oil in my coolant? | Ford Explorer Forums
rfishi
1998 Explorer V8 5.0
I drain coolant only a week or less after adding new coolant, and it's already all brown. Maybe this is just rust from inside the engine? But yesterday I replaced a hose, spilling coolant in the process. The coolant dripped all the way down the engine bay until it landed in a bucket under the truck. I then noticed a layer of oil on top of the coolant in the bucket (you know that rainbow type of mirage).
But I think that oil was just from the coolant flowing down the grimy, oily engine bay before reaching the bucket. Like it just picked up so old oil sludge from past leaks.
But how can I 100% confirm there isn't oil in my coolant?
I was going to buy a combustion leak detector, the ones with blue water that changes colors if combustion gases are present in the coolant. But would this test actually detect oil on the coolant, or just combustion gases? These tests are made to check for blown head gaskets, but what if my oil cooler is what's causing the oil to be in coolant? Will those tests work for this?
