Jaimec
- June 22, 2013
- 1999 Explorer
I've only had this truck for about 6 weeks, and have noticed oil in my radiator coolant reservoir The oil on the dip stick looks good, so it looks like there's no water there. I'm not losing coolant, and there is no tell-tale white/blue smoke (no smoke at all, actually), and the motor runs great. Mileage is normal, and power is great.
I'm assuming that it's a head gasket, and I will run a compression test on all cylinders. I've read that the original heads were notorious for cracking, but the lack of white smoke, and the fact that the oil is clean and I'm not losing coolant lead me to think it's just gasket related.
Any thoughts? Any other possibilities?
If it is gasket related, and I'd need to have the heads resurfaced, would it not be wise to simply go with new heads? I found them (new castings, not rebuilt) from National Heads for $204.00 each add in shipping and gaskets, etc., and it's roughly $550.00. Are these less likely to crack/cause problems than the original? Vehicle has 145,000 miles, incidentally.
Thanks!
Jaime
Thanks!
Jaime
