Blake D
- April 1, 2001
- Bella Vista, Arkansas
- '94 XLT
I want to know how capable the 4x4 really is.
Here is why i ask........
I recently got my 4x4 working again after banging it w/ a hammer to get the t-case to engague. This had gone out in the only BIG snow we have seen all year and I was frustrated, because last year the same thing had happened when we got 12 inches of snow. But it wasn't the tcase it was the auto hubs not working, the tcase was sending power the axle was turning but the wheels were not being locked in. Well at that time I was told there were no aftermarket manual hubs for the ex so I replaced the one side that was broken and went on. (I now know that mechanic was full of BS or not intrested in applying the Warn hubs which I wish I would have gotten). Someone has told me that to check the hubs turn the front axle and if it locks into the wheels they are working, I have done this and they appear to be working fine. If this information is inaccurate please let me know so i can do a better check. Since I "fixed" the 4x4 from last time I decided I wanted to try it out as well as get it to a place to see under the enging for breather tube location and extension. Well I put it into 4x4 , and everything to my knowldge enguaged. drove up next to a concrete slab about 15 inches high ( little high but similar to an obsticle when off roading) I was on hard gravel for a parking lot. I drove up to the edge stopped then slowly accelerated to creap up onto the slab. Well.. RPMs went up and my back passenger tire began to spin, so I backed off and tried it in 4 low with same results. Now I could have taken it alittle faster and used some inertia to get up but didn't want to hurt my tires or anything else, I wanted to crawl up onto it. Now I have a Stock 94 XLT 4 door except for the 31 BFG ko's and a K&N air filter, my back axcle is a 41 which is 3.23 or something, open. The top of the edge was about even with the center of the hub and there was nothing in the way just my tires touching the ground and the edge, yes I was lined up straight and yes I did the axle hub check after to make sure everything was working.
Now my question is why couldn't i make it up, I know it was a little high but nothing drastic. It is 65 and dry ground so nor climatic causes, it just seems that the front couldn't pull the ex up??? Is there some ratio that you look at to determine example. if it is one inch below the hubs you can make it, even with hubs 50/50 and edge higher than hubs, you better have a locker. It just seems for a rugged 4 wheel drive system it sure isn't impressing me. I know I have a Ex and not a Jeep Or hummer or some smart alick answer like that but I want to know how capable is a stock system and what would i need to get over that lip?
Thanks for reading this and hopefully I can get some educated ahd helpful information
Blake D
Blake D
