How Do I Access Steering Wheel Control Contacts | Ford Explorer Forums
Dennis J.A.A.
Location
South/central Wisconsin - Janesville
Orfordville
2017 Explorer Interceptor
Is there an easy way to get at the steering wheel switches so that I can spray them with contact cleaner?
I either need to pull each section out or maybe someone has a better idea.
You have to remove the airbag assembly to access the trim panel that those are mounted in
Ugg! I'm gonna have to get someone who is experienced with removing these without have it explode on me!
Naw, just disconnect the battery. You’ll be fine.
