How do I hook up my Vapor Canister Purge Valve? | Ford Explorer Forums
Wakeboy1337
Fort Pierce, Florida
93 XLT
The Vapor Canister Purge Valve was mission on this truck when I bought it. a few weeks ago. I know where the wire for it is, it's right by the IAC valve, and I know how to hook it up to the vapor canister. What I don't know is where does the other side of the valve hook up to? And does it even have a mounting point?
93 XLT with 4wd. Not Cali. emissions version.
I did a bit if searching and the vacuum diagram I came across just confused the hell outta me.
one is to the the canister to other goes to the throttle i belive. should be a small vacuum hose connection under the throttle. IIRC
Ahhh!! Someone plugged that hose with a bolt in it. I shall put it on there then.
hahah. u must get the stinky gas smell alot then
