how do I remove the half shaft from the rear diff box? | Ford Explorer Forums
OfficeVisit
'02 XLT 4X4
Does the half shaft just "pop" out from the gear box as I am told or is there a trick?
I have the rear torn down so I can replace the wheel bearings but am stuck on removing the half shaft. I do not want to "muscle" it ( I haven't broken anything to this point). Any tricks or just pry it out?
I have ordered the coil springs and struts from Rockauto.com and rear bearing/hub assembly from autopartsdirecttoyou.com. Replaced the front bearings about 3 months ago. Next I guess will be the transmission...
Any advice on uploading pictures?
thanks in advance for any assistance.
used hub puller instead
Glad I didn't pull the shaft out as it was not required. Once everything was unbolted from the spindle I used a hub puller from AutoZone and the spindle easily came off.
