How do I remove the tail lights on my 98 Explorer? | Ford Explorer Forums
spooky75
Howdy, I have a 1998 Explorer and I need to change a tail light bulb. I removed the top 2 screws but the housing won't come off and I don't know if i should force it. I do not know if there is another screw that needs to be removed.
Thanks!!
take the two screws out and just pull it has little plastic things that hold it in atleast thats how my 95 is should be the same thing
yep.
oh yea, give that sucker a yank haha. I've swapped out tail lights more times than i probably should have, and u just need to give a pull (try to pull straight out if you can)
Conversely, when re-attaching them, watch your wires. You won't break them or anything, but they will get in the way. Once everything is lined up, just give all sides a good tapping to push the screws back into their grommets and you're set!
Welcome to the site! :)
welcome
