Welcome to this forum! I've renamed, and moved your thread to the transmission & transfer case section. You have to remove the pan, take a bath in transmission fluid, remove the bolt that holds the filter screen, put 2 new O rings on the new filter, reconnect the bolt, and the pan. Use Mercon V fluid.
