gijoecam
Village Idiot
- May 31, 1999
- Trenton, MI
- 98 ExSport, '00 F-150
I was having issues with my blower motor not working properly. In the first two positions on the fan switch, the front motor ran in low, the rear would only run in the middle or high position (i.e. the rear would not run with its switch in low). The fans would both work normally in their highest two settings. I was under the assumption that it was a problem with the front blower resistor pack as I'd had trouble with it a long, long time ago. Boy was I wrong. The resistors are fine. Now I need to figure out a way to fix this:
The only thing I've come up with so far is to find a wrecked one in a bone yard. They've used that same resistor pack on most of the Ford vehicles for the last 10 years, so it shouldn't be too difficult to find. Does anyone have any other suggestions? Any possibilities someone's got that piece of the wiring harness laying around that they don't want?
I need to get 'er back up and running ASAP. Thanks, gang!
-Joe
-Joe
