How do you test coils? | Ford Explorer Forums
panteramatt
south jersey
07 Mountaineer V8
So how do you test your coil packs to see if their bad? Dont you use a ohm meter and test for resistence?
I believe you need an oscilliscope and a triggering circuit.. I haven't heard of any way that doesn't require semi-complex tools.
On my ex, I though I had a bad coil, but it turned out to be a cracked spark plug. I couldn't tell which one until the misfire was finally logged to the ECM. I read the codes using a bluetooth OBDII reader to my Android phone.
I thought you could just use an ohm meter?
