porshapower
- September 30, 2005
- jacksonville Florida
- 1996 explorer
I have the 96 with the idle tremble sputter. It only does it at idle. It is the 4.0 motor. Have replaced airfilter,cleaned the maf twice,new egr valve,new egr pressure sensor(dpfe),new plugs,wires are good,coil is good. Rans seafoam through it twice and techron. I cleaned the iac today and it looks clean inside (spring and little sensor). Anyway to actually test it before I throw more money at it. Checked for vacuum leaks. Sprayed carb cleaner all over this thing today and nothing smoothened it out. Sprayed carb cleaner into throttle body to see if it would possible be an intake leak no suck luck. I am running out of ideas and have no check engine light on. When you accelerate its perfect. Only when it sits at idle. ThanksNel
