Very easy. Remove the plastic liner that covers the top of the headlights, hood latch, etc. You will need a 10mm socket & phillips screwdriver. Once that is removed, you will see some screws that hold the side markers in place. Remove the screws that hold that on. Pull the side markers out. You will then see some screws behind where the side markers were that mount the grille to the body. Remove those screws. There are a few metal hold down pins/clips that need to be pushed or removed to get the grille out. Once its off, you will see the adjusters for the headlights. Don't remove them. You will see the headlight is attached to them using some plastic mounts. Using a pair of needle noise pliers, squeeze the plastic clip and then pull the headlight out. Don't forget to unplug everything on the headlight & side markers before removing it. Install in the reverse process.
