how hard can it be | Ford Explorer Forums
how hard can it be
grant83
2000 explorer
evening chaps
I was really excited to locate a full set of ranchos for my 4.0v6 ex based in the uk when I find out ive got poxy self levelling suspension on the rear.
that sucks
is there a way of replacing these with standard shocks .
cheers
Have you taken a look under the truck yet? Seems like they should just bolt on after you take the old off, then pull the rest of the air components if it bothers you to leave them on.
evening chaps
that sucks
cheers
You might want to look into these for the rear. The coil-over springs provide extra support in case your rear end sags after removing the old air shocks. Many here have installed these and like them.
Monroe 58617 Sensa-Trac Load Adjusting Shock Absorber
so ive ordered a full set . front rear and the small damper . from summit racing USA worked out with shipping @£247
Don't forget your rebate! $50-100 depending on which shocks you got.
