How Much To Refill The A/c ? | Ford Explorer Forums
daniel cauchon
Terrebonne,Province of Quebec
1995 Explorer Limited
Hi you guys...I was woundering my A/C is not very cold so I suspect that I need some juice in there !...so usualy how much does it cost to have it refilled ?
tx
From time to time the quickie lubes have a special on AC service.
Check your Sunday paper.
Woudl it be a 134 coolant on a 1995 Limited ?
Seeing as you are in La Belle Province and we Canadians are unable to purchase 134a over the counter, I would recommend Duracool. I just recharged my system with it this evening- it is easy and fairly cheap. Check out www.duracool.com for a retailer. It seems the large chains don’t carry it, so your give your indie jobber a ring.
Coolant doesn't wear out, it leaks out.
Fix the leak before charging
