Alan at work
- September 16, 2016
- 2003 Eddie Bauer Explorer
I did not ask about removing the bearing from the knuckle. I asked about pushing the drive shaft out of the bearing so I can get the knuckle off the car. Will the drive shaft go back through through the bearing while the knuckle is bolted to the car or do I have to remove the knuckle first?
No, knuckle won't pivot down far enough for splines to go out. Remove bolts holding knuckle assy, then should slide straight off. Sometimes if rusted on the splines hang up and puller is used to press on shaft while holding spindle.
I realize number 12 is prolly done by now but this is what I found. Idk about pivoting down but I got my drive shaft out with the top of the knuckle still attached to the upper ball joint. I busted the bottom bolt loose and tapped that out, couldn't get the toe link out so I disconnected the arm from the center chassis. Then I was able to tilt the knuckle up far enough to get the splined axle out the back. There was quite a bit of allowable inward travel on the drive shaft. Then I rotated the knuckle on the top ball joint 180, still with the control arm or whatever arm that is. I had a heck of a job getting the ball top joint out. After trying a chisel in the top of the crack (I was told the top of the crack is where you get the best results) I found a wedge and tried lower down the crack and was able to catch the tip of the ball joint at the same time driving it up and out. I should have done some homework first because there is some good video on youtube.
I incorrectly assumed the ball joint had a tapered pin but it isn't. Although it seemed once I had budged the pin a little it got easier to drive out. Dunno what made me think it was tapered.
