How to adjust headlights | Ford Explorer Forums
CobraJohn
Magnolia, Texas
2014 Explorer Sport
On the back of my Sport Headlights, there is a white nut (looks about 3/8" or 10mm).....just above it is a small hole with what looks like a gear or two teeth in the back of the hole.
What is the correct process to lower my headlights?
With lowering my sport it is level and my lights are a little high.
Had the same problem when I lowered my '13 limited. If I remember correctly, stick a #3 Phillips screwdriver in the hole you mentioned and that would turn the little "gear". I believe clockwise is to lower them.
I used a 10mm nut driver to adjust mine.
