how to bleed brand new calipers | Ford Explorer Forums
h.e.a.t.
2000 mountaineer
when bleeding brand new calipers, is it the same exact process as bleeding old brakes? Do you bleed each brake individually as you change them? How do you know when a new caliper is air free?
Ok. Cool. Should I bleed them individually as I change them or should I change all 4 of them and then begin the bleeding proces?
would he also have to bleed the master cylinder? or do you just have to do that if you change the MC. i know i had to bleed all the breaks and MC when i changed the MC a few years back.
I'm also curious to know if the truck should be running or shut off while pumping the brake pedal? I've seen some people saying on and some say off. I always thought that you were supposed to have it running while bleeding and shut off when refilling the fluid.
