Follow Up
So I got one plug changed this afternoon.......it took an hour, including the first 20 minute run to the hardware store.
I bought AutoLite XP104's and gapped them all to .054 (only 2 of the 8 were pre-gapped correctly and 1 was at .048 out of the box). I bought NGK CPB-FD001 boots, which came with new springs and a packet of dielectric grease for each one. Got all of it from rockauto for $92 shipped.
I had all the tools except the swivel socket, so I thought I would try without one. After I vacuumed out the manifold area and then used my little compressor to blow out anything left, I removed the air intake and realized you cannot get the back passenger plug without the swivel socket. The angle is just slightly too much. So I hopped in my sons truck and went to the hardware store to get a 3/8" drive swivel socket. Perfect, I'll be done shortly....
I started with the rear passenger side plug first because it is said to be the hardest. It wasn't that bad after I got the swivel socket.
I didn't remove the plug with the small wires connected to the top of the coil pack. I just removed the 7mm bolt and pulled the boot off the plug, then pulled the boot off the coil.
I connected the new spring to the coil pack and pressed it firmly to seat it. Then I used a Qtip and applied dielectric grease to the inside of the new boots, fed the spring through the boot and pushed it onto the coil pack.
The plug wasn't too tough to get out, I loosened it slightly and sprayed PBBlaster in the hole and gave it about 15 mins to work. Went back and it came right out. I put the new plug in (I put dielectric grease on the porcelain before installing it) and tightened it down to elbow detected 13ft-lbs. Pushed the boot onto the plug and tightened the coil down with the 7mm bolt. Easy peasy.....
Now it got interesting. I moved to the second plug closest to the firewall on the passenger side, since it seemed a bit challenging as well. My 7mm socket is a 1/4" drive and my new shiny swivel socket is a 3/8" drive. I had to use the 1/4" to 3/8" adapter and this is where I ran into the problem. The throttle body is too close to the 7mm bolt to use the adapter, you have to use just the socket with a swivel socket, or you don't have enough room.
I discovered this after my son took his truck to work, so I had to put everything together on my Explorer and drive to the hardware store again to get a 1/4" swivel socket, so I could start the second plug. However, now my engine block is hot, so I've decided to pick it back up again tomorrow when it's cooled off completely.
Anyway, not a bad project, but definitely make sure you have the right swivel sockets to keep a low profile. Otherwise, you will make this take much longer than the 4 beer process it really should be.
Hope this lesson helps others.....
