glenn_a
- October 9, 2010
- Sydney
- 97 XLT
hi there, could you please help me how to check if my HIGH / LOW range works......?
i have tried to select it on HIGH and i tried making a U turn and it seems its woking and then i fully stop and select it N position and turned the knob into LO and tried to take off but it feels the same to me....
while i was on the LO and i tried to go back to normal position (AUTO) but it kinda stuck on HIGH even sign on the 'DASH' cluster say's LO nor HIGH.
so i need to switch off the engine a re-start it again then it came back into normal mode AUTO....
first i checked; i can hear the relay clicked under dash when i change it into HIGH and into LO but when i tried to change it back to AUTO i hardly hear the relay click's....
second i checked the trasfercase motor under and i took it out and it seems it working but when i pulled it out i can turn the selector rod from N into HIGH but i cant turn it into LO, is that bad or ?
please help and tell me more what procedures i can do to make this thing work or check if its fully working properly.....
thanks!!!
thanks!!!
