how to do timing | Ford Explorer Forums
how to do timing
lynnboy021
billerica ma
2004 explorer
on a 02 4.0 sohc v6? i think my front chain is losse..
Seeing how its computer controlled the only way to advance/retard timing would be with a programmer. If you are hearing chain rattle, then your tensioner is probably on its way out
well i dont want to adjust the timing. if i am going to replace the tensioner, shold i just replace the chain also?
Well the 00M12 campaign replaced the tensioner, alot of members have had their timing chains replaced as a preventive effort to make the engine last. If I was in your shoes I'd replace the front & rear tensioners & timing chains.
true.. how do i know if the tensioner is bad? can i remove it and press the piston in and see if it is hard to push in?
so should i just do the 2 front timing first then later do the back?
SOHC V6 Timing Chain Inspection & Repair
I suggest you check the right first since if it's bad you'll have to pull the engine. Having the engine out will make it easier to do the left and the front if needed.
ok thanks but i also have another problem so i will just start a new thread..
