How to get to the antenna cable? | Ford Explorer Forums
KlausJ
Frankfurt, Germany, Europe
2011 Explorer Limited
Callsign
DG6FCR
Hi,
As I have a really bad FM signal quality, I want to install an amplifier for the FM radio. First I tried to install the shark fin antenna, but it did not help.
Therefore I need to get to the antenna cable. Does anyone know how to remove the MFT System or to get access to the antenna cable for FM radio?
Here in Germany, there is no Sirius coverage, so I can´t use it anyway.
Thanks for ideas and help
Klaus
Hi
It is always better to install a low noise amp close to the antenna. I think there is power in the roof because the GPS is there....
Yes, thanks. I found a really good (low noise) amp, but its really big.. Do you have any amps you would suggest?
