how to install a 1000 Watt power inverter? | Ford Explorer Forums
robotnik
Location
Arizona
Arizona
2003 Explorer 4.0L V6
Hello
I just got my hands on a 1000 Watt power inverter and i am looking to install it in a 2003 ford explorer. the problem is im not sure how i should install it. where would be the best place to put it, and how should i run the wire from the inverter to the battery? also is there any other info i should know before installing it?
i will provide pictures and more information if necessary.
thanks
there's a how to about it try the search I'm on my phone so can't find it for you
Big tip, keep it it a well ventilated area, otherwise they like to overheat.
Ok i finally got it installed after acquiring all the parts
here are some pics
i put the power inverter behind the second row seats
