HOW TO? Intake Manifold Gasket, EGR valve gasket | Ford Explorer Forums
murdok
Los Angeles, CA
1998 Explorer
can you help me PLEASE?
i need a step by step on some things:
1. intake manifold gasket replacement upper and lower
2. EGR valve gasket replacement, the tube and the valve.
1998 Explorer 4.0L SOHC
the parts are ordered and on their way. just need instructions. greatly appreciate it if you could help. thanks.
00m12 installation
98 SOHC Cold Start Idle problem
Starting my 00M12 Installation
Just ignore the parts about replacing the hydraulic tensioner and the oil restrictor.
There are two different EGR tube O rings. Make sure that you have the thicker green one.
You can use the search function for the EGR tube and intake manifold gasket replacement information.
i did order the green one thanks for the help
